tony rodaway
- Aug 28, 2016
I MAY CHANGE MY RUBBER FUEL LINES IF MY FUEL FILTER CHANGE DONT WORK
For members asking why change fuel hoses its because my car struggles to fire up from the key so may have air getting in .
Q! i have after market fuel pipes of very good quality but does a mm in size make a difference to the fuel flow and will it affect my lc performance.
let me explain what I mean.
if i take the fuel hose from the primer to the injection pump and say it was 7mm but i replace with 6mm or 8mm will it make a difference to my car.
i may sound stupid but want to understand how things work and for other beginners who just dont no how to solve problems .
two small rubber hose pipes from the fuel tank from MR T cost £21 so imagine how much it will cost to replace all hose pipes and still the problem is still there then may have only cost £5 ~10 for aftermarket pipes then if it solves the problem then up to you if you wanna phone MR T for correct pipes.
HOPE THIS HELPS NEW MEMBERS OR WEEKEND WARRIORS TO UNDERSTAND .
p. s dont forget my question.
