Fuel Tank Breather
Just poking around my LC to try to check the fuel tank breather - has
anyone done this?
I have found a pipe than runs from the top of the tank backwards to a
cross member where it attaches to what looks like a valve or filter and
then runs a pipe into the actual cross member and then just stops
there.
Does that sound right?
Mobile: 07971 540362
Julian,
Sounds right to me, except that in my cases it just ended without a
filter near the crossmember. Try blowing air in it and if you get
bubbles coming out of the thank you will be quite sure you'v e found
it.
Rgds,
Roman (London, UK)
'92 HDJ80
On Wed, 19 Jan 2005 16:15:27 GMT, Julian Voelcker
Hi Roman,
I have tried blowing air into it, but it takes a lot of pressure - not
exactly free flowing - if it a filter on it I guess it might need
replacing.
Also, I wouldn't expect bubbles in the tank - surely it is a breather
from the top of the tank and therefore doesn't dip into the fuel?
Julian,
Of course, you are right! (blush)... As an alternative, if you
pressurize the tank through this pipe, way you should be able to check
the difference after removing the filler cap.
Rgds,
Roman (London, UK)
'92 HDJ80
On Wed, 19 Jan 2005 16:49:32 GMT, Julian Voelcker
Time to get a bike pump out. The old ways are still the best.
Regards, Clive.
On Wed, 19 Jan 2005 16:55:32 +0000, Roman <[Email address removed]> wrote:
I will do, but would prefer to be able to pressurise it from the filler end to avoid blowing crap into the tank.
How is your 80 - any news of the problem?
Cheers,
Julian
Home: 01285 821 712
Office: 01285 821 910
Mobile: 07971 540 362
Julian,
80 is a hurtfull tale. =A31300 for a recon pump and timing belt
replacement, (while they had it off I asked them to do it.
Regards, Clive.
On Wed, 19 Jan 2005 20:51:51 +0000, Julian Voelcker
Clive,
Bugger! =A31300 - that's steep. Who did that job?
Rgds,
Roman (London, UK)
'92 HDJ80
On Thu, 20 Jan 2005 22:32:06 +0000, Clive Marks <[Email address removed]> wrote:
Hi Roman,
It sounds a lot, but I wouldn't be surprised for a recon unit.
I would have thought a rebuild would have been a bit cheaper.
Julian,
For all practical reasons a recon IS a rebuild.
As for the price - a year ago I pad AAI for a recon ca 250 quid.
Word of warning: be careful with all injection pump specialist ! Not
many can tell the difference between Bosch and Denso injection pumps.
If they mix parts from both bins you'll be in a lot of grief! Been
there, done that ...
Rgds,
Roman (London, UK)
'92 HDJ80
On Fri, 21 Jan 2005 10:31:45 GMT, Julian Voelcker
Hi Roman,
Come on, know that, but I have found that if you get a good company the
rebuild is often cheaper.
Yes it hurt. Done by a diesel specialist on the south coast. I phoned
Toyota to check on the price of a new pump, =A32000 to supply, =A33200 to
supply and fit. After this it seemed a bit better.
Regards, Clive.
On Fri, 21 Jan 2005 11:59:23 GMT, Julian Voelcker
Noooo... It can't be true! =A31200 labour charge to fit an injection
pump??? Clive, the "0" key on your keyboard is playing up!
Rgds,
Roman (London, UK)
'92 HDJ80
On Sat, 22 Jan 2005 21:56:28 +0000, Clive Marks <[Email address removed]> wrote:
