Matt Wright
Hi guys
One small but important thing that busted is the fuel gauge.. It shows we're on empty regardless of how much fuel we have.
We can quite happily cruise 300 miles and then fill up which is based on very conservative figures, but we can comfortably do 500 to 600.. What makes it tricky is that our fuel tank straps broke so it's ratchet strapped on so carrying 140 litres of fuel doesn't help at all.
So, I checked the FSM and have checked that the electrical connector is attached, the fuses are all good (it doesn't have a fuse tho?) so am guessing that the ball / float inside the tank has fallen off?
Any ideas, especially about a self fix welcomed. Else it's yet more cash to fork out. I'd like to get the new welded brackets (which will have proper joints not bends) done at the same time as the level fix..
Thanks as usual!
And hurry up with those bash plates Gav mine has served us very proud after protecting the transmission case through the worst road in the whole world
Matt
Thanks as usual!
Matt
