Fuse+relay
Seriously guys and gals, can anyone tell me where the fuse and relay is
located for the windows and central locking?
'93 HDJ81
Jeremy
Jeremy Llewellyn-Jones
Mob: 07831 458 793
The central locking is on the same fuse as the windows so fuse 16,
bottom right of the fuse panel in the dash just below the air vent by
the steering wheel.
It's also shown in the back of the owners hand book if you have one.
Best regards,
Jon.
-----Original Message-----
On Behalf Of Jeremy Llewellyn-Jones
Sent: 08 March 2005 17:04
To: [Email address removed]
Subject: [ELCO] Fuse+relay
'93 HDJ81
Jeremy
Mob: 07831 458 793
On 8/3/05 17:26, "Jon Wildsmith" <[Email address removed]> wrote:
Thanks Jon. I don't have a fuse 16, I only go up to 14. AC is fuse no 13,
normal type fuse and so far nothing for the windows. It must be on another
fuse but cannot figure it out.
Jeremy
22a Alexandra Grove
London N4 2LF
Tel: 020 8800 4987
Mob: 07831 458 793
On mine (94 HDJ80) the ordinary spade fuses only go up to 14 like yours,
and in the owners handbook 13 is labelled as 'AC - Air conditioning
system' so I think we're looking at the same fuse panel.
Below the ordinary spade fuses, there are two 'special' Toyota fuses
side by side, dusky pink with a see through window on the end on mine.
These are fuses 15 & 16, between the spade fuses of 5,9 & 13 and the
space for spare fuses.
In the handbook, 15 is labelled as 'FL HEATER Air conditioning system'
and 16 is labelled as 'FL POWER Power windows, power door lock system,
electric moon roof'. I can't remember how they're ladled on the fuse
board cover but you should be able to find them.
Best Regards,
Jon.
Sent: 08 March 2005 19:51
Subject: Re: [ELCO] Fuse+relay
13,
another
Jeremy
22a Alexandra Grove
London N4 2LF
Tel: 020 8800 4987
Mob: 07831 458 793
On 8/3/05 20:37, "Jon Wildsmith" <[Email address removed]> wrote:
-- Thanks Jon. Seems to make sense. The only reason it has taken me time as
I don't have my car with met at the moment as it has having some things done
to it. So I'm doing it all off Japanese manual, memory and of course your
help.
Jeremy
I've just swapped the fuses and..... no difference. But this is the fuse, not the relay. But is there a relay for the windows? I wouldn't of thought so.
Anyway, I must get on!!
Cheers,
Matt
Derbyshire, UK.
1991 HDJ80
old V8 Landy
----- Original Message -----
Sent: Tuesday, March 08, 2005 10:06 PM
> Best Regards,
> Jon.
help.
Jeremy
Further Info: http://www.landcruisers.info/lists/
