I'm normally not one for renewing gaskets or washers if they look good.
I'm currently working on the injectors and intake.
Off the to top my head I have the following: -
- 7 x gaskets on the nozzle leak pipe
- 1 x cylinder cover rubber gasket
- 6 x injector seat gaskets
- 6 x injector O rings (these are all either crimped or totally broken)
- 2 x egr valve gasket
- 2 x egr exhaust intake pipe (one at either end)
I reckon I only need to replace the injector seals and possibly the leak pipe gaskets.
Any thoughts?
Also, What about the injector pipes? Label on the timing belt cover says to replace at 140k km. I'm at 100k miles but the pipes look fine to me. Not sure if they were changed with the timing belt or not at 74k miles.
What's the reasoning behind changing the pipes? Should I do it? They look like a big ticket item in terms of cost.
Many thanks as usual.
Ken.
Any thoughts?
Ken.
