Gearbox/Transfer box filler
oldman
Looking to change the oil in my gearbox/transfer box.
Its the 4 speed box mated to the 2H engine.
I can't seem to spot the filler plugs!
The ones that appear correct have a rubber pipe that link them
to each other. Is that correct?
Also any ideas of quantities, thanks.
Hi,
My GB & TC don't have a hose link. are you sure that you don't have a vacuum change set up, some had them.
TC filler is high up on back of transfer case. empty & refill 2.2 litres.
GB filler high up on left hand side of gearbox. empty & refill 3.5 litres
80W or 90W gear oil for both.
hope that helps
Cheers Rodger turns out that they are linked because of low
pressure in the transfer case (so I am told) just drain and refil as normal.
Thanks for the quantities, I am off to buy some more oil.
