- May 26, 2014
No i havnt, is it that obvious?Hmm, you’ve not been following this have you Mike?
Yes Mike I have.
Yes Mike I have.
No I think you hid it pretty well. I don’t think anyone will notice.No i havnt, is it that obvious?
Steve is very good TBH. The WO ones had only partially gone. The type I had were from a few years back and I thought they were good to start with. I first noticed the rhs one flickering partially on startup. I didn’t notice any mottling or blotchiness to the WP ones I had but there is a little bit to the Phillips ones though it’s worth it for the better light.Im on it now, fully up to speed, etc etc..
What was the effect of a chip going rich?
the wp's get great feed back but i havnt been blown away by mine tbh. There blotchy for want of a better word. The blotchy segments brighter than the rest. At first i thought it could be my lamps so i removed the glass and gave them a good clean. It didnt make a difference.
i do need to ring him, he's a very helpfull chap, i just haven't got round to it.
At the risk of being accused of hijacking....
In looking to upgrade our headlights, I suppose that even with LED's, we should probably still upgrade the headlight wiring to give the LED's all the help we can?
While I understand the thinking, no, there really is no need. The current drawn is less than the original fillament lamps and LEDs work differently by actually needing their current to be limited. Replacing the wiring would give zero gain and could potentially introduce other problems. They are plug’n’play and require no wiring alterations at all.At the risk of being accused of hijacking....
Yes, Yes and no, the rubber boots are still usable as the lamps fit through them with a screw fit hestsink.iv ben thinking to upgrade to leds on this or not, are you all running in stock housings? do the led's produce less glare than hid's? and lastly, I have the rubber covers on the rear of my lights, looks likely these will be lost.. any disadvantage with that?
