Head lights black cover
Remus Romanu Jun 22, 2019
  1. Remus Romanu
    Remus Romanu New Member I am in romania
    2
    0
    1
    Map
    Hi guys, I need front lights cover from my prado please. When I can find them?
    Is for round head lights. Black plastic cover.
  2. AdventureWagon
    AdventureWagon Active Member I am in australia
    73
    17
    8
    Map
    Is this just a protective cover you're looking for or part of the OEM headlamp assembly?
    If the former then ones for the normal headlamp are common at least here in Australia but I've never seen this round type here. Maybe these would fit your round type. Happy to get you some pics of mine if you want to compare. Certainly your parking and indicators look the same.
    If the latter then is a swap out with some normal style ones possible/legal in your area?
  3. Remus Romanu
    2
    0
    1
    Map
    Is black protective lights cover only.
    But thanks
    Do you know a site for parts
  4. AdventureWagon
    73
    17
    8
    Map
    This is where I got mine from, Google search T235H for other sellers. But note these are for standard non sealed beam headlights not sure it would fit yours. Happy to pop one of mine off and take pics and measurements for you if you like.
    https://www.supercheapauto.com.au/p/protective-plastics-hlp-toyota-prado/SPO696191.html
  5. Shayne
    Shayne Well-Known Member Guru
    12,060
    4,022
    113
    Map
    Hi Remus , i would be very surprised if a full glass headlight wouldn't be a direct fit replacement , though you may end up needing the sidelight part as well i suppose https://www.ebay.co.uk/itm/272555911796
  6. RNS
    RNS New Member I am in russian_federation
    23
    11
    3
    Map
    They are fully interchangeable for up to 06.99
    For 99+ they are also suitable, but requires old style indicator lights and the grill.
Share This Page
    Dismiss Notice
