Lorin
- Mar 28, 2010
Yet again my headlights have managed to get muddy water in them (probably Lincomb!) which I want to sort once and for all. This time I am going to attempt to properly seal them (after I've cleaned them).
Last time I cleaned them I had to bake them in the oven (100 degrees for 15 mins IIRC) in order to soften the glue enough to get the lenses off. I then had to bake them again to soften the glue enough to put the lenses back on.
I did however have a go at removing the old glue only to find that it was utterly impossible - at least it was using a stanley knife as the glue was just too sticky and I didn't want to bake them any longer in case it damaged them. The old glue is also looking pretty poor and I doubt it is even sealing the lenses properly.
Does anyone know how I could get the old glue totally off - is there some sort of chemical I could use, or should I have a go with a heat gun?
