- Jan 8, 2019
So I've never used the heated window until today when I found out that it doesn't work.
So after checking that I've got voltage on one side and ground on the other, I checked that I continuity across the window, which I don't. I've checked and voltage seems to get to a different point on each piece of metal running across the window but they all seem to be broken, as at different point on each trace all I have is an earth connection.
I just wondering if you can get something to paint onto the broken traces to fix them or is it worth just getting a new rear window but I've got no idea how much that's going to cost.
Why couldn't it have been something easy like a relay or fuse ?
