warrenpfo
- Jul 21, 2010
I have just about finished planning my aux fuse box for the front of the car which will run things like the cb, 2x USB charging points, GPS and a 12v cig lighter socket. My plan is to run the front aux box direct from the battery so that if I stop at camp all the item running from it will still work with the ignition off.
i want to run the aux live through a voltage sensing relay so that I can't run the battery down beyond the point that its of no use but am not sure what that point is.
you can gat various voltage sensing relays some turning off at 12.2v or 10.8v or anything in between. What is the lowest voltage you would feel comfortable running you battery down too??
