Lorin
- Mar 28, 2010
I've just read all the excellent descriptions on here and the 'other' site re tightening the wheel bearings and am still slightly confused, so I need some 'advice for an idiot' - have I got this right
I'm trying to follow the instructions given here http://www.tlocuk.co.uk/forums/viewtopi ... sc&start=0
I only want to tighten the bearings. I am happy taking everything apart until I am looking at the two 54mm nuts separated by the lock washer. Then I take off the outer nut and lock washer.
Right, so I then do up the inner 54mm nut to somewhere between 43-60 ft/lbs with 50 ft/lbs seeming to be about right for running 33" mud terrains - doing all the checks as described in the write-up to ensure there is no excess movement. This I assume is the 'preload'?
Then I slacken the same 54mm nut off and do it back up - but this is where I get confused.... 3 ft/lbs is the 'correct' torque setting but am I right in thinking that Julian recommends 20 ft/lbs and Jon 35-40 ft/lbs (for 36" tyres)? So given my 33s, the 20 ft/lb setting should be about right?
Once that bit is sorted I then re-install the lock washer and lock-nut, doing it up to 47 ft/lbs and job done!?
Have I missed anything.....?
