Idle speed in hot weather
Simon
I've noticed this too, it drops to a point where it might stall but
doesn't actually, I rev up hard when stopped and this usually sorts it.
I've never had to use the choke or have the engine tweaked, apart from
when I return to North Africa and then it is tweaked to a much higher
rev anyway as I need this for hard dune driving at max revs in full heat
of 40-45 degrees plus.
I wouldn't worry too much about this to be honest, mine does it every
time we have a couple of days of hotter weather.
Renate
1hdt 4.2 1991 J reg desert modified
Simon wrote:
Anyone notice their idle speed dropping in this hot weather? Mine is
all
over the shop and I though at one point it was going to stall. Will
tweak
the idle speed screw and see if she is happier.
Simon Hughes
Hi Renate
Hmmm, high speed dune driving in North Africa? What were you doing? The
Paris Dakkar race????
Glad to hear that I am not the only one with a flagging idle in this heat.
And you are right a quick blip of the throttle sorts her out and shows her
who's the Daddy.
Simon Hughes
Principal Consultant
Tel: +44 (0) 207 2504710
Mob: +44 (0) 7973 288061
E-Mail: [Email address removed]
Website: www.marshallwarburton.co.uk
Disclaimer: The information contained in this message is intended only for
the recipient, may be privileged and confidential and protected from
disclosure. If the reader of this message is not the intended recipient, or
an employee or agent responsible for delivering this message to the intended
recipient, please be aware that any dissemination or copying of this
communication is strictly prohibited. If you have received this
communication in error, please immediately notify us by replying to the
message and deleting it from your computer.
