nivapilot
- Apr 6, 2011
Hi all,
How eassy?is it to strip, clean and reassemble injectors?
Can I do it with ordinary tools, or do I need specialist stuff?
I had to rebuild my engine, HDJ81 4.2 TD engine, when I bought the car, due to the last owner not checking the oil level and knocking it about a bit.
Once it had been rebuilt, I started it up and couldn't rev it over 1600 RPM..but once I had fed neat diesel through the pump it started running and revving ok.
The last owner had been running on veg oil, and it choked/gummed the pump up, where it had been sat for over a year before I started it.
Now the engine will be running ok and then suddenly puff out black smoke...especially when I boot it a bit, now the other day I had a guy following me, and he pulled in behind me, told me he was a diesel engineer, and that I had a problem with one of my injectors.
If when it was stood for a year, and then I have freed off the pump, I suspect that some gummy stuff has gone up the pipe into an injector? partially blocking?
Does this sound feasable?
