Hi Guys,
Some weeks ago I found my clutch of my HZJ75 4.2 of 1995 was slipping, so I ordered a new clutchplate and pressure group and meanwhile demounted the gearbox.
Then I found that the clutchplate was still good, but rather greasy. So I looked further and removed the fly wheel and then found that the oil sealing of the krank shaft was not that good anymore. So oil came into the clutch house and that made the clutch plate to slip.
After fitting the new oil sealing, flywheel and a new top bearing, I started to install the new clutch plate and new pressure group. Since I did not have a pilot bearing tool to position the clutchplate exact, I used a similar sized(diameter) socket and then screwed the pressure plate into place. I then started to place the gearbox back in place, but then the problem came in. The final 3 cm between the clutch house and the engine couldn't get closer.... We tried lot's of stuff but it just didn't move the final 3 cm. We looked around the gearbox and we are very sure that it wasn't somehow blocked.
So now we have the question, how exact does is come when placing the new clutch plate and pressure group? My best guess is that it was 85%/90% accurate centred. Could this be the cause why the gearbox couldn't get to the engine the last 3 cm, in such a way that the input shaft was pressing the pilot bearing or the clutch plate?
Or do you know any other reasons what could cause this 3cm gap...?
Thanks for you help in advance,
Best regards,
Zijad
Best regards,
Zijad
