take the glove box out and it's right there. 10-15 minute job to get to. You can see it and turn the fan etc, not sure how much of an effort from there.
I had a load of muck in mine. Looked like a rats nest
It's not the fan vibrating but seems to be comming from the air intake does anyone know where the fresh air enters the car from. I am assuming under the plastic trim under the wiper arms. Thought I would ask before starting to strip it down.
Remove the plastic trim. It's a few clips. Should take no more than a few minutes.
Once off, you can look down into the blower after removing the pollen filter. Don't recall there was much there that could be a problem. Only bits up there are the wipers arms and motors.
There is somthing making a resonating noise on high speed the noise is worse on the outside that the inside of the car. Having felt the motor there is no vibration so I assume there is somthing in the intake that has come adrift
Will have to get to the bottom of it as it drives me mad.
