IP stop valve
Hi guys
I got the answer for my start problem-the stop valve in the IP did
not function as supposed. Now I do remember we had some discussion
about that stop valve in the IP but do not remember
what was all about... Toyota mechanic says that this valve could've
been damage due to adjustment of the pump necessary for the new
turbo. Any ideas ???????
cheers
Lubo
'96HDJ80
Hi Lubo,
In one word bullshit, do the toyota mechanics ever think before they
open there mouth the turbo has absolutely nothing to do with the IP. The
fuel shut-off valves do occassionally die for no apparent reason.
Craig.
Lubomir Kolev wrote:
Hi Craig
I knew you will answer:-)
good for us to know what you wrote but Toy guy thinks they have done
something wrong and I might be not charged for that valve which
itself cost 130 Pounds without the labor..
the thing is that that happened right after they changed the turbo-so
I might be lucky for once ....
cheers and thanks for the reply
Lubo
On Oct 10, 2006, at 10:10 PM, Craig Vincent wrote:
