Ok. I can rev her up to 1200 rpm but that's it. So I've got control on the first 10% of movement on the throttle lever. The rest of the movement nothing happens at all.
What I did so far: there was a gargling noise from the engine and it sounded like it's not firing on all cylinders. I adjusted the tappet play and the noise is gone and the engine sounds a lot better but still no revs.
I checked the timing belt (it's due to be changed and will be changed). It has not slipped and the camshaft is only 1.5mm behind (measured from the position marker on the sprocket). This shouldn't be the cause for the revving problem.
I have not checked the fuel supply yet, because... it doesn't really behave like a fuel supply problem (clogged fuel filter or air being drawn into the system) but I may be wrong with that.
Other observations:
When you turn on the ignition there is no engine control light coming on. This could be
I would be grateful for any idea from someone that is familiar with this engine / injection pump.
Other observations:
- Because there is no such light (there is a computer though)
- The computer is broken
- The light is broken
- There is a wiring problem
- Oh... I'll check today if there is a fuse blown for the computer.
