Bat21 said:The motor on eBay is the later engine and is for the bare engine only... there will be the cost of all the ancillaries on top of that.
I noticed this post about one guy that is doing just that... see his comment below.Brett said:There are quite a few people who have fitted these engines to the earlier trucks in Australia now & apparently the difference is like night & day![]()
Im in the process of putting a 1hdfte into my 80 now. when its finished im calling it my HEFTY F-TE. cause its been hefty on my wallet. hope it will be worth it in the end.
That was one of my thoughts before I stripped her down.Brett said:What about trying some K-seal, it seems to work on all the Land Rover 4.6 V8 blocks that crack or go porous?
That may be a cheap solution that works.
Bat21 said:So these Land Cruisers aren't as bomb proof as we think![]()
Thanks Gav, I did see it but..... I'm not totaly sure the bore is cracked nowGav Peter said:http://www.landcruiserclub.net/forum/viewtopic.php?f=26&t=8594
Just in case you haven't spotted this one Paul...
The dye doesn't lie, not very clear images but I'm sure you see the resultsBat21 said:So, I have ordered some of THIS which will hopefully provide a definitive answer.
Yes, quite an easy job with the bolts accessed through the oval ish hole in the bottom of the bell housing. Just give it a tap when the bolts are undone to make sure it's not stuck to the flywheel but it sits on the gearbox input shaft so stays put, less chance of damaging it like that than pulling it out with the engine.Bat21 said:Am I right in thinking that the torque converter needs to be unbolted from the drive plate and left in the auto box when the motor is removed?
