Problem with eBay there is too much choice, would have been good to see some installs and which one where used.You can get cheap 12v led strip lights that are rgb with a remote from ebay, you can even get waterproof ones as well.
Thanks will have a look.Have you looked at Korr Lighting
https://hardkorrlighting.com/en-gb/product-category/camping-lights/
Grimbo see the same Nat Luna I recommended above for CraigI have used a company called LED It for interior light kits for work vans ....brilliant company and the supplied lights are very durable ...I have some mounted above the side sliding door .....
What I'm after though for both the Landcruiser camp setup and the Camper van is some LED lights that can change from white to red at the flick of a switch ...reason being every bug for a 10 mile radius is attracted to white light and red/amber means you retain your night vision so walking off into the Ulu is much easier ........ typically I've seen some on Aussie sites but getting them to the UK is not cost effective as postage is more than the awning lights......
