Well I finally got some spare time to take a look at what broke on LB on the last outing at Lincomb farm. The good bit is that Ian's parts arrive as promised
which meant that I could start on the replacement job.
So started off with taking off the ASFIR protection plate, and then the front wheel, brake calliper and then the whole front axel assembly. Had some issue with the split pin on the big ball joint at the bottom which meant I had to find another way of removing the assembly.
Fortunately there were 4 bolts holding the lower ball joint assembly together which I was able to undo and remove the whole unit.
Once the front axel assembly was off and out of the way you could quite clearly see the problem:
And the other side
So to get this off was a bit more difficult. In the end it was easier to remove the complete sleeve that holds the drive shaft to the front diff:
4 bolts to the diff (one was a right nightmare.... sigh) and 2 larger ones on the other side.
Once the bolts were off, a small bit of tapping and the whole lot comes off including the drive shaft which is held in place with a snap ring:
You can also see the other end of the broken joint assembly. Unfortunately I did not order this part as I thought the issue was with the shaft itself..... oh well, just need to order that up.
Once thing I am not sure of is if I can get the rest of the snapped of bit's out of the drive shaft, I probably won't bother, and just use the new one that I got
More to follow when I get the other part....
And the other side
