- Oct 13, 2010
Jimbo4x4 said:So far so good Just a thought, when you fit your new bumper you may need to cut the exhaust back a bit so it won't squash flat the first time you drop off a rock step (I know because it happened to me after I took my towbar off )
Also, slightly OT, how old is your spring lift? Noticed a bit of driver side lean there and if the springs are too new to be worn out then they've probably been fitted the wrong way round. The kits are usually handed, with the drivers side springs being a smidge longer to counteract the stress from the torque the engine/drivetrain create.
Jim.
the exhaust will be coming straight through the bumper and finishing flush with it. on the other side in exactly the same position will be a hole exactly the same size as the exhaust hole, and this will have a fog light set into it. should look good when its done.
thats interesting about the suspension. the ironman lift kit was brand new about 6 months ago and i too have noticed it leans slightly.
its all coming off in a few months as i want to wire brush, rust kill, hammerite and waxoil the entire underside including all the axles etc. so i will be removing all the suspension when i do it.
i will have a proper look then, thanks id not thought of that.
