hi,
i have an lj70 2.4td with 2lt engine and 170.000km.
now have emerged any problems...
first problem:
in the morning when are the temperature about -4 to 0 c° the cold start aren't good than any time ago...
the engine (if i do a little pump with accelerator) start up with 3 cylinder for 4/5 second and after go normally (with the low rpm a little bit lower than normally)...
i have changed all the 4 glow plugs, principal relè on engine (starter relè), pre hot timer but the problem are present curently..
you know some possible solutions?
second:
the lancet of the water temperature in first time stay in the normal position at 1/4 of the meter but about some week had change the normal position at the middle of the meter..sometimes had a peak (togheter the lancet of the level of gasoline) at the max level of the meter on the red zone!..
i had change: thermostat, water temp sens on the engine, liquid of radiator with apposite coolant liquid...
please help me..!
sorry for my very bad english!
best regard's
lorFred
first problem:
second:
please help me..!
best regard's
lorFred
