- Mar 1, 2010
Yes you need some sort of impact l/h driver with hardened teeth on it. Trouble is a good quality locking stud has a hardened surface.
Those squiggly type stud heads all look the same but are all slightly different so keys will be slightly different. As in Yale lock keys.
If not hardened you could drill through the head with the same sized drill as the o/d of the bolt thread. Use a punch then pilot drill to ensure the centre.
