- May 23, 2015
Hi all
I have the Redarc 1225 dcdc charger. Now I find I need to change the aux battery.
You can choose the battery charging profile for AGM, Li, gel or std lead.
I had my eye on a Victron 110ah battery AGM.
The Victron data sheet says that the recommended charge voltages for its batteries are as follows:
Float Voltages range: 13.5 -13.8
Absorption voltage range: 14.2 - 14.9
The Redarc says that on the AGM profile the maximum voltage is 15.3 V and the float voltage is 13.3V.
So the 15.3 is above the fast charge Victron range of 14.9.
And the 13.3 is below the Victron range of 13.5
So my question is are the Redarc and Vic battery compatible? Are these voltages close enough or will the battery be damaged? Or damaged in a meaningful way?
Many thanks
Many thanks
