- May 23, 2015
Morning all
I am looking at the battery charger/solar MPPT system at the heart of the electrics in truck.
I will be installing solar (around 175W) and have the normal user units (fridge, water pump, LEDs lights and charging points) but not heavy usage today.
I am currently deciding on the aux battery set up - either a c. 120Ah lithium or 2* 100Ah AGMs.
My goal is to be able to park up for e.g. a week without worrying about the batteries.
So I am looking at the Redarc BCDC units; the 1225 charges at 25 amps and the 1240 charges at 40 amps. The prices are not so different.
The redarc website says use the 1225 if you have an aux set up less than 200Ah and 1240 if above that. But reading around and even talking to Redarc customer support they say that the 1240 will be fine if you have more than one AGM or if you have a Lithium becos in both cases there is sufficient capacity of the battery/batteries to effectively take the 40amp charge. (As you prob know both Redarc systems checks the state of the battery each 100 seconds for voltage and adjusts its charge rate appropriately.) My concern is about not wanting to over charge the batteries.
A part of me says pick the 1240 as it allows for upgrade in usage/batteries in the future. Another part of me says keep it simple dont overbuild.
Anyway would really appreciate any real world experience or advice from all of you.
cheers
cheers
