message posting - now gearbox problems 1997 Prado
Tim
Where are you in the country? Here (Devon) there is a very good gearbox
place nearby in Exeter.
Christopher Bell
Gearbox problems!
Landcruiser Prado 1997 (automatic 3L TD)
=09
=09
I recently had the gearbox and transfer box rebuilt due to
horrid clunks. Turned out to be a thrust washer that had disintegrated
and the chain in the transfer box had worn and stretched.
On reassembly it drove quite differently and I was getting
strange vibration on the change from first into second and second into
third - the greater the load the worse the vibration.
The valve chambers have now been stripped and reassembled but
I'm still getting vibration on some gear changes and sometimes a painful
clunk as the power feeds back in after a period of cruising (ie in gear
but with no throttle)
Other problem is that it is tricky to move hi / low and low /
hi. I could always do this smoothly in neutral before. Now I have to
either switch off the engine or move to the 'park' position. Is this
correct?
Its now back in the workshop! I had hoped it would all be
'tight' and smooth and not making clunks like those you get from a
landrover drive train!
Anyone got any hints on how to sort this out?
Tim Maw
Tim,
Who did the work on the auto box, was it you or someone else?
If you get really stuck contact Rodney at
http://www.automatictransmission.com.au/ - he is probably one of the
most knowledgeable people on LC auto boxes around.
Mobile: 07971 540362
Skype: julianvoelcker
1994 HDJ80, 2.5" OME Lift
