Netgear Readynas Duo
Dave Docwra
1,591
11
38
Enfield
Thanks Guy's, It is doing my brain in.
I keep resetting it & waiting upto 24 hours for it to rebuild/boot, then when that fails start again doing something different & again waiting.
Handbook/pray book very limited.
Raidar can not find it so no Frontview to check what is going on, I have just fitted a new hard drive so I will leave it again for another 24 hours before launching it into the unknown.
Crispin
Administrator
Staff member
I am in great_britain
Feb 24, 2010
5,970
576
113
springs, gauteng
24 hours is not that long if it is rebuilding. I have an array which takes a weekend to rebuild a lost disk. Have you rebuilt before?
Richard Jackaman
246
2
38
Scottish Borders
If the Duo is resyncing a volume it will usually show up on Raidar as such. I can't remember how long it took mine to resync 1.5T but it wasn't 24 hours.
Is this a new disk you're adding or a replacement for a failed one?
What size is the current/new disk?
Dave Docwra
1,591
11
38
Enfield
Hi Crispin, never rebuilt before, there is very little stored on it as it would not work previously with Win7 to recently, hence the reason to fire it up & use.
Hi Richard, I gave up with the 500gb disk that was fitted & have now attempted to try it with a new 250gb disk.
I check the netgear router that it had been previously working with & DHCP is turned on, it is also not showing up as an attached device. I think that is why Raidar can not find it.
Richard Jackaman
246
2
38
Scottish Borders
I've got both a Duo with a pair of 1.5T drives and an NVX with 4x500G drives, both work with any OS I try to connect to them with.
Have a look here http://home.bott.ca/webserver/?p=346 for help in setting up a Duo from scratch. There's some info on resetting drives used previously in other systems.
Also have a trawl through the forums on readynas.com as Cripsin suggested. Loads of info on there.
Crispin
Administrator
Staff member
Feb 24, 2010
5,970
576
113
springs, gauteng
Sorry, can't be of more help. I don't use netgear (still don't believe they've actually got a user! :ugeek: ) so can't shed much light one it. :(
I hope what little you have stored on there you can retrieve or worst case, you not precious about :shock:
Andy Harvey
343
3
38
Cheltenham, UK
It may be corrupted and need to do a Boot recovery, either TFTP Boot recovery for Flash based systems or RAWWriter for USB or CF based systems. You can download stuff off the Netgear site to do this stuff. Sorry, never seen one of these devices before, just done a quick search on the web and come up with this as a possible.
There is also mention of possible DIMM memory module re-seating. Often works to sort out problems on PCs so don't see why it wouldn't be worth it on one of these.
Dave Docwra
1,591
11
38
Enfield
Thank you all for your help, I think I will stick to mechanics & send it of for testing & maybe repair.
Thanks Again
Dave.
AdBlock Detected
