Hello everyone
My name is Craig, I'm new here and I have recently been fortunate enough to be able to purchase my 1971 (I think) FJ45 Land Cruiser which I have been chasing for more than a year. The cruiser is running the 2F engine with the 4 speed transmission and has barely been run in with 29122km on the clock (the odometer seems to be working fine so I'm hoping that those are original kilometers). This has been a long time goal for me and I'm over the moon that my cruiser finally found me
*The chassis # is FJ4594537, if someone can provide a more accurate estimate on the year of production I will be very grateful, I may be way off. The regisration papers I have say that the year of maunfacture was 1985 but they are notorious for making mistakes as the details would have been filled out by the importer. The chassis # also doesnt seem to match those made in the 80s....
The vehicle was bought in South Africa and from what I can work out from the chassis # it would probably have been among the first batches that were imported into South Africa at the time. I dont have any more info on its life in South Africa but it was likely used on a farm as were most cruisers. It was then imported into Botswana in December of 1996 where it was put to use on a game reserve in the Tuli Block as a safari/game viewer vehicle only being used once or twice a year. This is propbably the reason for the low km reading. Thankfully they kept it original and didn't cut or convert the body in any way, they just added some bolt-on seating at the back and the original body, roof, windscreen and doors were all preserved. I would say that about 75% of the original interior trim remains.
I took over management of the game reserve in question just under 3 years ago and at the time the cruiser was owned by the outgoing manager. He tried a few times to export the vehicle back to South Africa with him but C-19 coupled with a few other things made it nearly impossble and after a year of me nagging he finally agreed to sell it to me.
I haven't wasted any time and I dove straight in, I have so far pulled off the body and removed the engine and drivetrain. At the moment the cruiser in in bits with all the different pieces, nuts and bolts ect all carefully photographed, catalogued and stored. As you will see from the following pictures, I am now at the stage of prepping to remove the wheels and differentials so that I can start cleaning and sanding down the chassis for paint. I am not a mechanic by any means and we are located way out in the middle of the Botswana bush under my humble workshop roof but with the help of the workshop manuals, help from those on the forum and hopefully a bit of common sence, I will manage to give the old girl a decent restoration. This won't be a nut and bolt resto as I simply can't afford that but rather a soft restoration with the ultimate goal of being able to use it as a daily drive and capable mid-range overlanding rig.
My short-term goals are:
1) to get it painted and mechanically sound
2) re-install the 2F engine and 4 speed transmission
3) enjoy it as it was intended for a while
Long term goals:
1) powertrain swap, possibly to the 3l D4D deisel engine with 5 speed transmission. Basically to a more modern and fuel efficient engine more suited to long distance travel. Im sure there are many options to be explored.
2) change the load bed/cargo area to a liter flat tray with a half canopy and fold down sides.
These long terms goals may change over the coming years....
I'm looking forward to the adventure and to learning as I go, I'm sure mistakes will be made but hey thats part of the process. Can't wait until I have the old girl back in top shape and on the road once again.
Cheers,
Craig
Long term goals:
Cheers,
Craig
