all week my car has been doin my head in but this morning was the final straw so i set fire to it....... only joking! 5.15am wouldnt start, so jumped it again. something is causing the batteries to drain but i didnt have a clue what untill i went through all the fuses 1 by1 and found the cause of the drain is something to do with the pass side front headlight. rain has stopped play for now but i wondered if anyone else has had the same problem? if i disconnect the bulb for the main beam ad dip the drain seems to stop, but surely even a dodgey bulb cannot drain a battery at the rate mine was, can it? with the engine not running and the lights off i was loosing about 1 volt a min. or could it be the stalk? didnt think of that till just now. jobs are mounting up on this car now, even got water running down the windscreen on the inside!!!
