Oil build up in intercooler
Tom, an oil film is nothing to worry about, the breather system vents into
the inlet pipe after the air filter, excessive oil means you have too much
crank case pressure caused by worn bores.
We offer Old Man Emu suspension for the 70 series, usually from stock. for
expedition prep check out www.britishexpeditionvehicles.co.uk
Ed
-----Original Message-----
From: [Email address removed] [mailto:[Email address removed]]On
Behalf Of Thomas Albertini
Sent: 15 November 2005 13:37
To: [Email address removed]
Subject: [ELCO] Oil build up in intercooler
Apparently this is quite a common problem, oil build up in the air intake
pipes and intercooler caused by oily air being sucked up from the engine. It
doesnt seem to be a problem for me now (i.e. im not losing much oil and the
turbo seems fine, no smoke), but should I get it looked at before I leave on
a long trip next year (round trip to India), or just clean out the
intercooler as best as possible.
Im also wondering what general maintenance / new parts I should put in
now before the off. THe car is quite old, an LJ70 1990 with 140k on the
clock. I figure a general suspension upgrade and obvisouly full service
etc., but other than that Im not planning on doing much. Is there anything
else that really should be done to the old girl that any of you would
reccomend.?
thanks, and see you on sat.
Tom
LJ70, 1990
-- European Land Cruiser Owners Mailing List Further Info:
http://www.landcruisers.info/lists/
Hi Thomas,
Yes, I wouldn't worry about it too much.
Ideally start from the ground up. Obviously a lot will depend on what
has been done recently on the vehicle and the type of driving you are
likely to be doing, but I would go for:
New wheel bearings, steering knuckle bearings and seals all round on
the axles.
Repack the CV joints, unless they are the original ones when I would
consider replacing them - you can't really tell if you need to do that
until you open them up. The last two 80s I've opened up the axles on,
both had around 140k miles on the clock - one set of CV joints looked
almost new and the other set were extremely worn with a lot of rust in
the ball.
Possibly new disks - again depends on if they are original or not. As
a guide, most original disks on 80s tend to last around 90-120k miles.
New clutch/thrust bearings - again depends if original.
New brake pads
Possibly replace remaining suspension bushes - several will come with
the upgraded suspension kit.
As you say, upgrade the suspension and make sure the springs and
dampers you choose are correctly rated for the loads you will be
carrying.
Extend the diff breathers.
Possibly replace the battery with a new one.
Don't forget that anything you do replace that isn't that worn can be
used as your spares kit.
Replace the thermostat.
Replace all belts and filters.
Replace fuel filter - also consider fitting extra filter like a Racor
550.
Possibly a new alternator if original. Same for aircon compressor if
you have it.
Replace all fluids and flush out the gearbox (if auto) as well as flush
the radiator.
Do bear in mind that if you are driving in harsh conditions the wear on
the vehicle is going to be a lot higher than pootling up and down the
M4 so service intervals will need to be a lot closer together.
Here (http://tinyurl.com/7d9a3) is a handy guide to the sort of
maintenace will need to be prepared for.
Having said all that a stock 70 should be able to do the trip with just
basic maintenance so it is up to you how far you want to go with
things.
Mobile: 07971 540362
1994 HDJ80, 2.5" OME Lift
Hi Thomas,
the axles.
the ball.
New brake pads
carrying.
550.
you have it.
the radiator.
things.
Hi Thomas,
Wheel bearings and CV joints are items that tend to get ignored by
dealers and others when it comes to service time. They only ever touch
them when there is an actual problem. If maintained properly they
should last for years - the concensus is to strip down, inspect and
regrease about every 20k miles.
The other thing to note is when servicing the wheel bearings they need
to be torqued up properly, it is very easy to either just tighten them
up without attempting to bed them in so they loosen off pretty quickly
or just to over tighten them.
Over 50% of the TLCs that I have worked on recently have had loose
wheel bearings and a fair few of them looked as though they didn't have
enough grease in the CV joints indicating possible trouble.
Hi Thomas,
