Part identification.
Hi,
Clive is taking his car apart again. I have the AC condensor and
expansion valve in the shed, compressor on the floor. While I was
there I thought I would take out the Cruise control ECU and modify it.
Only problem is, I don't know what it looks like. The article I have
out is a cream plastic case with the following numbers on. Toyota
88650-60300, and, 177300-2951 12v. If any one with the parts manuals
working on their PC could look this up and tell me what it is I would
appreciate it. Thanks.
Clive Marks
Home: +44 1293 514600
Mobile: +44 7821 491897
Skype: Cobminor
Crawley, West Sussex, UK.
Hi Clive,
Fortunatelly I still have your VIN details so:
Doing a search on Cruise control identifies part number 88240-60081 for
01 '95 to 08 '96 - Computer Assemmbly Cruise Control - the part number
later changed to 88240-60180 from 08 '96 to 01 '98.
This appears to be located under the centre console above the gearbox
tunnel.
Hope that helps.
Mobile: 07971 540362
Skype: julianvoelcker
1994 HDJ80, 2.5" OME Lift
Thanks Julian, I'm impressed a bit. Not the bit I was looking for
then, better put it back and carry on.
Clive Marks
Skype: Cobminor
Hi Clive,
Only a bit? I won't bother next time ;-)
Thanks for that Julian, I have just taken out the ABS one, bit of a
pig, as I thought it was by the drivers footwell.
Clive Marks
Skype: Cobminor
By the way, it was a pig as the Clifford guy put all the alarm stuff
in front of it.
On 09/06/07, Clive Marks <[Email address removed]> wrote:
Clive Marks
Skype: Cobminor
