smart ass comment.
it looks to me like the step to make getting in and out of a car/van easier.
100 series tailgate
I have come across some of your type of step before and they never seem to last that long when they get salt and road grime in them.
Could you not ask you supplier to cut them to size when you are buying them?
I expect I know the supplier and they do cut to size some times it works out cheaper then pissing about cutting it all your self.
Stu
I only have experience of the small one I linked to but max width on that is slightly larger than the spec says.Anyone got any experience with these - bearing in mind we have tread at 250mm and 300mm so the wider tread would be right up to the stated capacity limit of the saw
Get you name out there and you will do well. Try a company called Carlisle bus parts they would buy them from you.
stu
