Even more low down torque and more horses on the intercooled 1HD-FTE to tow with....sweeeeeeeeeet
1HD-FTE[
edit]The
1HD-FTE is a 4.2 L (4164 cc)
straight-6 24
valve turbocharged diesel engine. Bore is 94 mm and stroke is 100 mm, with a compression ratio of 18.8:1. Output is 164 hp (122 kW) at 3400 rpm with 280 lb·ft (380 N·m) of torque at 1400 rpm. The fuel system is direct injection, and adopts the
electronic fuel injection (EFI) system.
Redline of this engine is at 4200 rpm.
The 4 valves per cylinder are actuated by the SOHC, by using bridges so each rocker actuates a pair of valves.
The version with
intercooler as fitted to HDJ100 station wagons has 202 hp (151 kW) at 3400 rpm with 317.1 lb·ft (430 N·m) of torque at 1200-3200 rpm with a redline reaching 4000 rpm. A lower output 122 kW non-intercooled version powers HDJ78 Troop Carrier and HDJ79 Utility versions
