Neal Guthrie
- Mar 8, 2010
Ok so i have had my prado for a while now, Since March. When i got it, about a week later i had starting issues. almost like it was out of fuel. the first time it would not start i though i was out of fuel and so i pumped over from the long range tank. it statred no issue. i though it was this and the fuel gauge was not working accurately. drove home about 25km on issue and the fuel was pumped from LR to main. ended on half a tank. the following morning it just would NOT start.... spent 8 days going over the vehicle..... im limited in electronics.... so i was checking and double checking as i went.....
i checked and tested all relays and they seemed fine. i then place direct power to the fuel pump and Voila! it started first turn of the key!! or i have ruled out the fuel pump. i then placed a gadget (forget the name) on the wires at the Pump. this send signal up the wires and i followed with the pen while it was beeping along the wires hoping to find a short or broken wire.... followed it right up to the open circuit relay below the dash on the drivers side. (right hand drive vehicle) right so check that relay again, on problem. bought a new one, still wont work..... i then Bridged that relay socket with a test wire and it started no problem!!!
right, so connect my gadget to that relay socket and followed the beeps right up the the ECU....... so where i am right now is that there is NO signal coming from the ECU telling the relay to close to let the power through to the fuel pump.....
what tells the ECU to let power through??? I have checked the EFI relay, checked all fuses that i can think of and that i have found in manuals and tech pages.... i do not want to borrow a mates ecu as if there is a short and i pop his i will be bleek!
there is an alarm/anti-theft device in the car but i have traced those wires for three days and they are NOT cutting into any power wires on the ignition. they only really power the windows and siren when the buttons are pressed (beep-Beep) and the central locking.....
i have done the check for engine codes and faults and it displays nothing.
could the key transponder be the culprit as this is the kind of safety device the transponder is i think??
at the moment i am driving the vehicle with a bridged relay socket but i would like the issue sorted.
Anyone have any ideas.....???
regards.
regards.
