Problems with toyota landcruiser 2013 with dpf system
legendz
dominican_republic
hello I am installing an emulator in a Toyota landcruiser 2013 European version and install everything as the installation manual says but now I have a problem is that the vehicle is smoking a long white and need to know if anyone has experience installing this emulator below I describe it I made:
1- install the emulator connecting wire 7 says
2- a co-worker told me it is not necessary to screw the auxiliary injector requires the manual because it is only used for DPF regeneration (I have doubt that)
3- I do not dpf light on, or anything except that the values ​​of temperature sensors are very high and dpf vece launches check and says sensore failure temperature
4- the heavily white smokes rental car off to a point that the person is scared of both white smoke and everything was installed after the remuevo dpf and stop smoke
Please someone who has experience installing this emulator the seller has given me all the necessary support but do not go to road thanks
2 questions
Did you remove both dpf filters completely?
What kind of emulator did you use?
