Rob
I have symptoms that suggest that the rear prop on the truck has a UJ problem, the rear output seal on transfer case gone twice in very short amount of time so I would like to get to the bottom of this before I replace the transfer case rear output bearing and seal. I have not removed the prop yet but I have found that there is radial and angular play in the prop. It is minimal but it is there, I would say its about 0.5 to 1 degree of angular play and you can move the prop up and down a small amount when your under the truck. The FSM does not specify radial and angular tolerances only total runout which will only show up if the prop is bent. So do I need a new prop?
