Re Bumper bolts
Hi
Metric fine thread blots are quite easy to get hold of. But also dot for
get the make sure you get the right tensile strength bolts for the job.
The existing bolts of the yota will have a reference on then on the head
you can use that as a point of reference for your repayment bolts
Ray dadd
-----Original Message-----
On Behalf Of Benoit Bernard
Sent: 01 June 2007 13:50
To: [Email address removed]
Subject: Re : [ELCO] Bumper bolts
I am doing the same thing but already start! Yet I am build my own winch
bumper from steel plates and welding post. You will have a bad time
finding them bolts. Toyota uses special bolts with fine bolt threads. I
had to special order them just yesterday. The metric sizes of bolts are
normal but rare to find them in such fine bolt threads.
I found them at a grossiste (whole seller?) here in France. They will be
rust plated in cadmium where the original Toyota bolts are only black
plated in some thing that does not resist rust so much.
Do not give in to temptation and use super hardend bolts. It is better
to have your mounting bolts bend or brake if you have a collision than
to have your chassis bent.
Benoit
----- Message d'origine ----
De : Peter Browning <[Email address removed]>
=C0 : [Email address removed]
Envoy=E9 le : Vendredi, 1 Juin 2007, 14h04mn 06s
Objet : [ELCO] Bumper bolts
Once I get my LC back from having its new head gasket fitted I=92ll be
fitting the ARB bumper.
On the assumption that I should fit new bumper bolts regardless of the
condition of the old ones what bolts do I need? Is there a Toy part
number? Or should I get them elsewhere?
Pete
Checked by AVG Free Edition.
Version: 7.5.472 / Virus Database: 269.8.5/826 - Release Date:
31/05/2007 16:51
_____
D=E9couvrez une nouvelle fa=E7on d'obtenir des r=E9ponses =E0 toutes vos
questions ! Profitez des connaissances, des opinions et des exp=E9riences
des internautes sur Yahoo!
<http://fr.rd.yahoo.com/evt=3D42054/*http:/fr.answers.yahoo.com>
Questions/R=E9ponses.
Ray,
Your new currency confused me, probably Benoit as well =93repayment bolts=94 =96
must be cause it=92s a Friday, took 30 seconds of looking at it before I
realised to spellchecker had corrected a misspelt =93replacement=94 to
=93repayment=94!
I think it is a sign of the superior engineering that metric fine is used,
most car manufactures used some fine threads but Toyota seem to specialise
in it =96 strangest bolt on my 40 series so far is an M11 fine set bolt (ie
has a shoulder, not threaded all the way). (Only thing odder than an M11 in
the metric range is M7 =96 never seen one, probably never will).
Malcolm Bagley
Stafford UK
FJ45 '75 & FJ45 '76
Behalf Of Ray Dadd
Sent: 01 June 2007 14:09
Subject: RE: Re : [ELCO] Bumper bolts
Hi
Metric fine thread blots are quite easy to get hold of. But also dot for get
the make sure you get the right tensile strength bolts for the job. The
existing bolts of the yota will have a reference on then on the head you can
Ray dadd
bumper from steel plates and welding post. You will have a bad time finding
them bolts. Toyota uses special bolts with fine bolt threads. I had to
special order them just yesterday. The metric sizes of bolts are normal but
rust plated in cadmium where the original Toyota bolts are only black plated
Do not give in to temptation and use super hardend bolts. It is better to
have your mounting bolts bend or brake if you have a collision than to have
your chassis bent.
Benoit
Once I get my LC back from having its new head gasket fitted I=92ll be fitting
the ARB bumper.
condition of the old ones what bolts do I need? Is there a Toy part number?
Pete
Version: 7.5.472 / Virus Database: 269.8.5/826 - Release Date: 31/05/2007
16:51
_____
D=E9couvrez une nouvelle fa=E7on d'obtenir des r=E9ponses =E0 toutes vos questions !
Profitez des connaissances, des opinions et des exp=E9riences des internautes
sur HYPERLINK
"http://fr.rd.yahoo.com/evt=3D42054/*http:/fr.answers.yahoo.com"Yahoo!
16:51
16:51
Don=92t worry Malcolm
It is my crappy typing and not looking what I am doing sorry
Ray
On Behalf Of Malcolm Bagley
Sent: 01 June 2007 14:20
Ray,
bolts=94 =96 must be cause it=92s a Friday, took 30 seconds of looking at it
before I realised to spellchecker had corrected a misspelt =93replacement=94
to =93repayment=94!
used, most car manufactures used some fine threads but Toyota seem to
specialise in it =96 strangest bolt on my 40 series so far is an M11 fine
set bolt (ie has a shoulder, not threaded all the way). (Only thing
odder than an M11 in the metric range is M7 =96 never seen one, probably
never will).
Malcolm Bagley
Stafford UK
FJ45 '75 & FJ45 '76
On Behalf Of Ray Dadd
Hi
Ray dadd
Benoit
Pete
31/05/2007 16:51
_____
31/05/2007 16:51
31/05/2007 16:51
Hi all,
My TJM front bumper may be different from ARB, but is probably fitted
in a similar way - four M14 bolts 8.8 grade on each side of the
chassis rail bracket.
I wouldn't worry about fine thread. Once the bolt gets slightly
corroded it won't get undone anyway. A spring washer will do.
In such condition my bumper has survived several hundred miles of
corrugations and a few impacts against grassy and sandy banks.
Rgds,
Roman (London, UK)
'92 HDJ80
On 6/1/07, Ray Dadd <[Email address removed]> wrote:
On
=96
e
ie
in
On
get
can
On
ng
ut
ted
ve
ing
r?
7
questions !
utes
7
7
