TALAMAN
- Jan 11, 2018
Hi Folks!
Went to climb aboard the J95 this evening, stepped on to the rockslider step thingy and went head over heals!
Not sure who fitted these things but they are secured with one bolt at the front (now sheared) and one at the rear. Both seem to be mounted in to what looks like a body mount----maybe? Rubber for sure.
So, I have one sheared that I will need to get out (front) and one at the rear, I undid the nut holding it up but am left with a threaded bolt that is fixed but very loose and wobbly inside the rubber mount and not wanting to play nicely.
This hanging bolt had a straight sided hex for the last 10mm nearest the ground as shown in pic.
1. Does any body recognise these bars?
2. I have no documentation showing if the rubber wotzits are body mounts - enlighten me if you can please?
