Not familiar with these as I have 120 with one long scv - so some thoughts.
Did you have a good clean all around the areas before removing old scv's? Any introduced sh/t in the pump could give problems.
Did the new go back in the same place and electrical connections checked ( I don't think.its possible to get them wrong way around)?
Were both O rings properly in place on each scv, and did you lubricate ?
Did you introduce them slowly and square on, so as not to twist/deform them, but if it drives ok then doesn't look like that. Could be any or none of those mentioned or connected with it.
Good luck.
