Removing little RHS dash panel
I've had some switch lights die in the little RHS dash panel that
contains headlight height adjuster, rear fog switch, etc. Not
essential, but it would be nice to get them working again.
Does anyone know how you get that panel (or maybe just the switches)
out? And any advice on replacing the little bulbs in the switches -
bulb sourcing, disassembly, etc?
Christopher Bell
Devon, UK
1996 1HD-FT
Hi Christopher,
I suspect that you will need to pull the main dash apart in order to
pop the panel out, although you could try to get you hand up underneath
to do it.
As for the bulbs, once you have the switches out it is pretty obvious
how to get the bulbs out and you should be able to get most from our
local auto factors - failing that you will need to go to a dealer -
when removing them, make a note of which one came from where so if you
have to go to the dealer you can specify the ones you can't get else
where.
Mobile: 07971 540362
Skype: julianvoelcker
1994 HDJ80, 2.5" OME Lift
