Re: Running wiring from the front compartment to the rear ??
Sorry I haven't posted these earlier but been a bit hectic last couple of days. Had to fix rear heater pipes as going away next week
Weather permitting.
Any way, I started at the rear of the chassis, drivers side next to the fuel tank. I found this easier to get the pipe past the stiffening tube just by the back wheels.
In this picture you should be able to see the tube laying in the chassis
The tube carries on inside the chassis to under the floor where my feet would be if I was driving. I took it out here to be able to get up into the engine bay following the rear heater pipes.
This pic shows the tubing going up into the engine bay inside the front wheel arch
I tucked the tube behind the servo and around the inner wing going to the battery
The wire isn't connected to the battery at the moment as its still a work in progress
At the rear of the truck, the wiring from the bumper lights enters through a large rubber grommet. I just enlarged this and tucked the tube into the inner wing where it sits at he moment waiting for me to get my finger out and get on with it. I siliconed all round the grommet inside the wing.
when I finsh this off I will post the rest of the wiring inside the rear panel
