Series 80 fitted with 6 speed gearbox
The Turbo install was not without a lot of care. The last 1hz I turboed was at 650,000 km and the motor went on to do over 1 million Kms. It was also at 1 bar (15psi). Just got to follow some basic goldern rules.
Photos of the gearbox and bell housing preparation as well as a vib on the machining on their way. Looking back on it I have to have a bit of a laugh but no machining shop would have a go at it unless I totally stripped the gearbox and handed them an empty housing. That seemed to me a much bigger challenge than working out how to do the machining myself. Turned out I was right.
Trying to workout how to upload files. Size is the issue so will copy in a Dropbox link.
https://www.dropbox.com/sh/wimintdbszgd118/AAAVadWbXAbItJpYLAAlClrca?dl=0
I would love to see the vids & pics of the conversion.
@Nissanclubman : what plc do you use to monitor it?
I settled on the Velocio Ace 3090v5 and standard HMI through the RS232 port for the Turbo and engine monitoring. They have some cool tools and can either use ladder or Flow chart programming structure. http://velocio.net/ace/
However I have other mods I am planing and have outgrown the 3090 so am working to convert it across to an Arduino UNO mico controller platform.
the programming of the ace looks a lot easier than the arduino.
reminds me of the Siemens Logo! programs
btw love your setup with the router
I've used router bits in my jig borer for ally and brass, The bits are surprisingly hard and long lived.
Yes it's surprising what can me done with a bit of the "Have a go" mind set. The risk was I could have stuffed up a perfectly good MT82 gearbox and through away the $780 it cost but on the other hand the 1HZ thanks me for the conversion every day I drive up and down the Toowoomba range.. Its a whole different car to drive.
Wow! You actually welded it successfully! That’s not easy without major distortion, cracking or a host of other problems.
Hats off to you for that bit alone!!
:clap:
Hat's off indeed! I love the 'have ago' attitude. :clap:
I have often found that many projects do work but it is the finer issues like the speedo connection, and gearstick/Hi Lo selector position that spoil the overall effect, any issues such as this?
regards
Wow this conversion excites me, have been mucking around with different ideas about replacements for my 1fz due to obvious high fuel consumption and lack of balls. So now that i know this gearbox can be done, im wondering how an 80 would go with complete 3.2&auto? Do you have more details on what had to changed as far as driveshafts, transfer case, mounting etc would be very interested!! Cheers
:clap:
Can I contact you for further information on this conversion?
Hi Dan and welcome, you need to get your post count up to 10 or 15 I forget which but then you’ll be able to send a private message or ‘conversation’ as the forum calls it.
It’s a friendly helpful forum with great folks so pop over to the ‘introduce yourself ‘ section and well, introduce yourself, then postup some funny pics or jokes or comments and you’ll soon be at 15. Looks like Nissanclubman is still a member. He may well respond on here as the forum sends an email if you put the @ in front of the name.
Good luck
Rich
hi, new by there, i'd like to follow the swap 'cause my "HDJ"45's H55F is a nightmare to drive. gaps between ratios and far too low first gear. had less problems in the BJ71 because the 13BT was far more prone to get in turns.
thank you, regards.
Just thought I would start this tread for anyone who is interested in fitting a 6 speed gearbox into their Series 80 1HZ. I started the project a few months ago and the big issue was selecting the right gearbox. Looked at everything from the land Rover Discovery and all the late model 6 speeds and decided on the MT82 out of the 2013 Ford Ranger. The main reason was the easy by which it could be realigned from a Passenger side drive shaft alignment to a driver side to suit the 80 series Diff input.
For the moment I will park this thread, gather all my photos and story details and progressively update it over the next few days.
In summary, after over a Million kms I decided to give the 80 series motor a refresh and while I was at it, a gearbox upgrade which has been well worth the conversion and did 75% from my home garage. Apart from buying the gearbox the whole conversion cost about $700.
Update 1:
Just as an opener and I apologises if this offends anyone who fits this category, but as with all forums there are always people who provide opinions ! based on very little or no first had experience yet claiming what they say is with Gospel accuracy. If this is you please go play in another topic.
However if you have any serious doubts or thoughts about something then I am more than happy to explain my finding and experience. Yes the car has only been on the road a few months and the test of time is yet to reveal its issues.
Secondly, this is purely an "experiment" and aimed at solving the age old question of giving the 80' series longer legs for high way running and much better ratios (2-3 and 3-4) between gears on hills that suit the engine.
Selecting the gearbox:
As I mentioned the MT82 is in a lot of vehicle and is coupled behind lots of different motors. The Mitsubishi BT50 and Ford Ranger both have the 5 cyl turbo motor rated at about 470 Nm of torque and compared to the 1hz's of any version, is way over rated for the job.
The three main questions I was interested to solve (apart from the strength) was the rotation of the output shafts, realigning the output shafts from passenger side to driver side (as per old 80 box) an matching the gear rations to match the 1HZHDT torque band between gear changes better than the old box.
This was done in two ways.
Gear box ratio comparison
Gear 80 series MT82
1st.......4.529........5.441
2nd......2.464.......2.839
3rd.......1.49..........1.721
4th .......1...............1.223
5th........0.881.......1
6th........N/A ........0.794
Diff ........4.11 .........4.11
Upgraded diff ratio to the 80 series EURO diff ratio 3.879 (Jap, SA, USA and Aus was 4.11)
The next thing to do was to get a box and old 80 series bell housing and start measuring up to see how to match the two together and what work needed to be done. The major differences I found were these.
Clutch hydraulics uses a concentric cylinder
Input spline was different
Box was 150mm longer
Output to rear wheels was direct alignment from gearbox input and not from T/F case.
G/Box bell housing was incorporated with the G/box. No separate Bell housing.
There were lots of other minor things that 95% of us could easily work out.
The first and most important thing was working out how to couple the MT82 to the motor. I thrashed through lots of options and decided to machine both the 80 series and the G/box housings down, tig welding a 15mm thick adaptor to couple the two together. This had to be very accurate so as to suit the input shaft length and support bearing in the crank shaft.
I have all these measurement is anyone is interested. A huge issue was I couldn't find anyone engineering workshop who would take on the job of machining the MT82 bell housing with out stripping the G/box apart so with a lot of creativity and lateral thinking I did it my self. Will post a vid to show you how simple it really was.
The second part of the adaptor issue is the clutch and support bearing in the crank shaft.
I managed to find an "Off the shelf" heavy duty organic clutch that had the exact internal spline of the MT82 and its O/D fitted the 80 series pressure plate perfectly. A bit of good luck. The other thing I found was the O/D of the MT82 input shaft support bearing was exactly the same as the I/D of the STD bearing used by Toyota. This was a pure fluke and a good omen..
That's it for the moment and will post some photos and vids of the bell housing machining method I used. Remember I did it all from my home garage so is very unorthodox.
Can you give the measurements of the HZ transmission hood, in addition to which clutch disk you used? How was the configuration of the levers within the hj80?
