servicing prior to Portugal trip.
wobbly
What do I need to consider servicing prior to my trip to Portugal.
I will do the basics - oil, fuel filter, air filter, oil filter.
I changed the rear diff oil after thr flooding, butwhatcame out was better than what I put in, so ihavent done the front as its a bit fiddlier and the front diff oil should have less wear then the rear. Worth doing though?
May start replacing the atf fluid.
What about cv joints on the props, I recall they are greasable.
I still have to replace the osf cv joint.
I am going to botrrow a ramp for a day, wjust need to make sure I plan it all.
Pete
