C11ONX Member Joined Nov 8, 2012 Messages 134 Dec 31, 2012 #1 Hi i am wanting to check and adjust my tappet/valve clearance and was wondering if the tappets are shimmed or not thanks
C11ONX Member Joined Nov 8, 2012 Messages 134 Jan 1, 2013 #2 Are they adjustable without taking the whole thing apart
Jon Wildsmith Super Moderator Supporter Guru Joined Feb 24, 2010 Messages 7,084 Garage Country Flag Jan 1, 2013 #3 you have to measure the gaps then remove the cams to change the shims on any that are out of spec. It would help people answer questions if you put what model Landcruiser you have in your signature Last edited: Jan 1, 2013
C11ONX Member Joined Nov 8, 2012 Messages 134 Jan 1, 2013 #4 Hi thanks for that. If I knew how I would. It's a 4.7 v8 100 series
