ByronJ
- Jul 7, 2012
I have been wanting to fit an auxiliary fuel tank to my 1994 80 series (Elsie/LC) for some time but found the options available were expensive and unnecessarily complex - at least for my needs. Chatting with Ed and Trevor at Lincomb led us to a kind of joint project and here is the lads actually fitting the prototype to my car last week.
As you can see the tank fits above the spare wheel space at the rear of the car and is so tucked away that it sits above the exhaust and the bottom of the chassis. The tanks are both filled via the original filler. The fuel flows into the auxiliary tank and then on to the main tank via gravity. The bottom of the auxiliary tank is about 50mm above where it is connected to the main tank.
Obviously this transfer flow is not as fast as a standard pump flow so when filling more than 90 litres you will need to fill in two lots with a 10 minute break in between. Many retail pumps will not let you take more than £100 of fuel at one time anyway so you have to pay in two lots. Generally I plan to fill to 80 litres or so most times and only use the whole capacity of the system when I see there is an advantage to doing so.
Initial experience is very good. On my first “big fill” it took 175 Litres. There was capacity for a few more litres but 175 seemed a good number and my heart and wallet could not stand much more strain! With my long term average of 5 miles/ Litre that extends my range to 875 miles.
The fuel gauge does not move at all until more than 300 miles have been covered. Then it moves slowly down as both tanks are emptied, accelerating its descent (to normal I suppose) once the auxiliary is emptied.
The lads have a bunch of ideas for simplifying and improving the system, including a version which will allow the wheel carrier to remain in place below the tank. Early days yet but I am very happy with my tank.
