knicko
- Dec 23, 2012
I have noticed a slight leak at the forward end of my transfer box, where it mates with the back of the automatic gearbox. It is not enough to drop oil on the ground as I would certainly have noticed this. However, there is definitely wet oil around the join. It certainly appears to be oil and not ATF, so I presume I have an oil seal gone on the input shaft of the T Box?
I have searched the forum and see from a photo by Bob Murphy (I can't attach photos to posts yet) that the input shaft has a metal cover which appears to house an oil seal that sits over the input shaft. The metal cover is also gasket sealed and bolted to the forward face of the T box by the look of it.
I presume that the mating surfaces of the T box and Autobox are just bolted together and do not need sealing as there should be no fluids in this space?
Looking at this, I presume the fix will be to disconnect both propshafts and electrical plugs from the T box, then uncouple the T box from the autobox and remove the T box, so that I can get at the offending seal and replace it? Will I also need to lower the back end of the autobox to gain access to some of the bolts?
Once the T box is out, can I replace the seal just by removing the plate around the input shaft, or will I have to open the T box itself?
Once drained of oil (not much I know), how heavy is the T box as I will probably be tackling the job on my own with car ramps?
Are there any other things/problems that I need to consider?
Many thanks, Nick
Many thanks, Nick
