If you have a leak on your Steering Rack Control Valve from the shaft out to the steering wheel this could be your problem and could save the cost of another rack. Parts from Toyota for a few pounds.
Remove the rack.
Note. 8 sided "NUT SUB-ASSY, BEARING GUIDE" (Part No. 44015A) guess there is a special tool for removing this, small cold chisel was used by me, it's not very tight.
Spot the bearing, this needs to be pushed out to replace the seal.
This is the seal IMO which will be leaking SEAL, OIL (FOR POWER STEERING CONTROL VALVE) part no. (44201F)
Remove the rack.
