- Jun 30, 2011
Ok, so I've been chasing a niggly fuelling problem around for the last while and thought I had it sorted. Well the bugger keeps coming back. I've replaced filters, cleaned fuel lines, dropped the tank, cleaned the egr and air intake and all to little avail. After some searching it appears the suction control valves an the back of the pump are the likely culprit. My local diesel specialist can supply them, but they don't come cheap - €340 for the pair.
I've tried searching online, but I'm finding conflicting information. Australian sites list one SCV, but the diesel specialist says 2 - one red, one green. I have found red/green Denso SCV here >> http://www.dieselpartsdirect.co.uk/...-scv-red-green-kit-suction-control-valves.htm but no definite answer on if they are the correct part - list Nissans. They would save me €100 including postage if they were right. I've emailed, but got no reply. Is there any way to check, or are all Denso SCVs the same?
