Sudden loss of power steering - help urgence!
Hello the guys and Renate,
Well I am back here after loosing so much data under computer change.
My 80 is almost finiish now with new block but after test drive
suddenly the steering is so hard - no power steering. So we check
fusible for that steering speed sensitor and it is OK.
Then we get smarter than monkey and we test volts that going to
steering box to work electrovane and there is only 6 volts. I think
that is too little volts but we have not manual for power steering.
What you think?
So maybe you can help us diagnoste why no more power steering? The
pump is drive by cascade of gears, not drive belt.
Benoit
Hello Benoit,
the same hapend to me on Monday so I know how it feel.
I have noticed that the engine had problems when the steering wheel was
in the end position - then I went to Toyota garage to solve the problem
and my pump died on their parking lot.
You are right - there is no drive belt.
In my case the pump was obvious candidate so they removed the pump and
opened it. It was in bad shape with the metal parts in contact. Surface
of the metal parts was damaged so we had to inspect the entire steering
oil line for possible small metal parts (i don't know the English name
for that).
The result was in my case - new pump.
The good news is that the separate parts for the pump are available in
the toyota part catalogue.
Best regards,
Tomaz
1996 HDJ80 (1HD-FT 24V, manual gearbox), OME Lift (6 cm), Safari
snorkel, Front runner long ranger tank (170L)
Interesting.
I don't have any stalling or other pump issues... but my LC has recently
developed a steering fluid leak from the pump area. It's not major, the
fluid level drops about 2 - 3mm on the dipstick per 200 miles of driving.
I can't see where the leakage is coming from because it doesn't seem to leak
at idle. But without fail if I go for a longish drive there's ATF
everywhere.
Is there anywhere obvious on the pump where a leak might appear?
How much is a new steering pump? Does anyone know?
Pete
Hi Pete,
unfortunately :) I can tell you the exact price for the pump: 780 EUR.
Tomaz
Ouch!
Worth considering secondhand?
Pete
-----Original Message-----
Behalf Of Tomaz Sustar
Sent: 28 February 2008 13:57
To: [Email address removed]
Subject: Re: [ELCO] Sudden loss of power steering - help urgence!
Hi Pete,
Tomaz
Hi Pete,
if you can get one ... I was trying hard without success. We have many
shops which can rebuild your pump but at least the housing must be in
good shape which was not the case with my pump.
Tomaz
Often the problem isn't it?
Was it difficult to remove the pump? What's involved in removing it?
Pete
Sent: 28 February 2008 14:11
Hi Pete,
Tomaz
Hi Pete,
at toyota garage they told me that I'm the first one with such a problem
Regarding pump removal - my skills are really poor so I'm leaving that
to the mechanic who was not complaining much - if this is of any info to
you :)
I think they usually charge one hour labor for dismounting and one and
the half to put it back.
Tomaz
Hi Benoit
So sorry to hear about your troubles with the steering.
Your luck is very bad just like mine.
I can only think maybe there is an interruption of power to the steering.
It happened to me when the engine stalled a few times I broke down, so maybe
the pump which the engine drives is damaged.
As for the leak peter, its usually a seal problem and you can get the seals
but then you need to get the steering box in and out etc.
Mine has leaked for years and tried the stop leak which did not work.
So tried some brake fluid in the mix and it seems to be working but dont
know about the long term.
The theory is the brake fluid expands the seals a little ,so we shall see.
john 92HDJ 80 1HDT
----- Original Message -----
To: <[Email address removed]>
Sent: Thursday, February 28, 2008 12:58 PM
Subject: [ELCO] Sudden loss of power steering - help urgence!
Hi John
It's my steering pump that's leaking, not the box.
Anyone know the removal procedure for the steering pump please?
Pete
Behalf Of john byrne
Sent: 28 February 2008 14:49
Hi Benoit
Has anyone fitted a third party steering pump to an 80?
Just a random thought but there is a spare v-groove on the crank pulley so a
separate belt driven pump should be easily fittable??
Pete
Pete
Isn't it in RM184E - REPAIR MANUAL FOR CHASSIS & BODY is available from
www.mudtoys.com/manuals/RM184E.pdf (121MB)
(Courtesy of Jon Wildsmith)
It's a big download - 116MB according to my browser. Pages SR28 onwards
(pdf pages 507 onwards) describe it.
CB
| Hi John
| Pete
I'm just about to replace my powersteering pump- I am hoping that it can be
repaired though as it's not totally gone, it's just groaning and not
supplying proper flow and pressure. It's got a whole lot worse since off
roading it though!
How does a speed sensitive box appear different to a standard box, and as I
have a 93 UK 80 series what would I likely have?
Behalf Of Christopher Bell
Sent: 28 February 2008 15:26
Subject: RE: [ELCO] Sudden loss of power steering - help urgence!
Pete
CB
| Hi John
| Pete
Hi Peter,
Leaks from the power steering pump is quite common and is usually just a case of replacing the rubber seal on the fluid inlet pipe at the bottom and the copper seals on the high pressure outle
07971 540362
Sorry sent the last message too soon.
You also need to replace the copper seals on the high pressure banjo bolt outlet at the top.
Whilst at it I tend to actually remove the pump (two 14mm nuts) and check the drive gear, blow out the pipes to flush the oil and clean it all up, making it easier to pin point future leaks.
07971 540362
That's worth a try.
Are the seals Toyota only?
Pete
Behalf Of Julian A.R. Voelcker
Sent: 28 February 2008 15:47
Hi Peter,
Found it, thank you Chris. I didn't even think to look in the chassis
manual.
Pete
Pete
The seals are standard size rubber or copper seals - I started just getting them from the multi packs you can get from the likes of screwfix.
07971 540362
Thanks Julian
I'll pop into Screwfix tomorrow then. Shame, as I walked straight past their
door today.
Pete
Sent: 28 February 2008 16:46
Pete
I got a full steering pump rebuild kit with all the seals (seem to remember there are 2 or 3 inside the pump) off ebay (roodogs is the seller in Australia).
Easy to get the pump off and put it back on, hardest bit is getting the cog off the front to be able to split the pump apart.
Think the seal kit cost around 40 pounds.
Andy Harvey
Cheltenham UK
Date: Thu, 28 Feb 2008 17:09:45 -0000
Reply-To: [Email address removed]
Thanks Julian
door today.
Pete
